Create New Product
| 1.0 | 03.01.2025 | Bogomil | First publish |
The are couple of ways to create a product within Hemi. It can be via API, via import or even via marketplace integration. Our focus here is how to create a product manually directly from the Hemi UI.
The whole figma project available - https://www.figma.com/design/UdlQyxZ0F3ZLxcZUdY1RG2/Multichannel-Pro?node-id=3090-73754&t=XztPZoSiKyChC4K5-0 Prototype available - TBA
Create New Product
The user can directly click on the + button from the menu under Products section to create a new product
This will prompt the user to the product creation screen where the data can be added manually following a three step wizard
On the final step we also ask the user if want to create a listing for the product or just save the product.
Full list of Product fields:
| Name of the Field | Field Type | *Required (In terms of required to be filled by user)** |
| Title | Text Field | No |
| SKU | Varchar | Yes |
| Application Data | Varchar | No |
| Condition ID | Dropdown button with following options: |
New (with tags); New other (see details, without tags/box); New with defects; Manufacturer refurbished; Seller refurbished (Re-manufactured); Used (Pre-owned, Like new); Very Good; Good; Acceptable; For parts or not working; Like New; | No | | Variation Group | Varchar | No | | Brand | Varchar | No | | Barcode | Integer | No | | EAN | Integer | No | | ISBN | Integer | No | | MPN | Varchar | No | | VAT code | Dropdown button with following options: Empty Value; 0; 5; 15; 20; | No | | UPC | Varchar | No | | Weight | Integer | No | | Height | Integer | No | | Width | Integer | No | | Length | Integer | No | | Is Bundle | Check Box | No | | Is Expanded | Check Box | No | | Calculate Price | Check Box | No | | Bundle Error | Text Field | No | | Error Text | Text Field | No | | Parent bundle | Varchar | No | | User Category | Varchar | Yes | | Hemi Category | Dropdown (Read Only) | No | | Cost Price | Integer | No | | Description | Text Field | No | | Attributes | Text Field | No | | Content Manager | Dropdown | No | | Main Image | Varchar | No | | Listing Image | Text Field | No | | Additional Images | Varchar | No | | Video URL | Varchar | No | | GTIN | Varchar | No |
