Default Single Record View (In progress)
The purpose of this page is to describe Single (Detailed) record view in Hemi 3.0.
This section will include the requirements for creating new product, order, import & export.
Each page is described on separate documents.
Here, we have listed the general requirements that need to be covered for the respectively single record view
Requirements
- Fields to be aligned
- Fields to have one size
- Font size - TBD
- Opened sections & subsections to be colored in purple (TBD color)
- Wizard functionality for Create New Product & Order
