Edit Single Product
| 1.0 | 03.01.2025 | Bogomil | First publish |
The whole figma project available - https://www.figma.com/design/UdlQyxZ0F3ZLxcZUdY1RG2/Multichannel-Pro?node-id=2880-93827&node-type=canvas&t=0EZgLju6zQgQuCY3-0 Prototype available - TBA
Edit Single Product
The edit mode will look the same way as we are creating a new product.
