Hemi UI / Diatleslinqn (TBD) (WIP) / CRUD (Create, Read, Update, Delete) / Form Fields / Validators / List Validator
List Validator
This validator will be checking if the selected value for it is part of the list of values that it can be. All fields with this validator will have the options of Empty Value that it would be null. For this validator we are to provide a list with all its options.
Default error message:
Value/s doesn’t match any in the list
