Listing Multi Record View
| 1.0 | 03.01.2025 | Bogomil | First publish |
The whole figma project available - https://www.figma.com/design/UdlQyxZ0F3ZLxcZUdY1RG2/Multichannel-Pro?node-id=2868-79545&p=f&t=gfOccX4BxmXfJrxB-0 Prototype available - https://www.figma.com/proto/UdlQyxZ0F3ZLxcZUdY1RG2/Multichannel-Pro?node-id=2868-79545&p=f&t=gfOccX4BxmXfJrxB-0&scaling=min-zoom&content-scaling=fixed&page-id=2868%3A79545
Here the things get interesting and we are adding many different features and options for the user. If the user click on the image or the title we want to lead the to the detailed listing view. Again in front of the title we want to have a thumbnail of the main image if there is no main image we need to prepare a dummy image saying “No Image” for example but we do not want to break the structure if Main Image is missing.
When we click on one or more than one product we gonna show the action bar at the bottom of the page which gives additional options for the user like:
Clear Selection - deselect all products and hide the action bar
Create Listing - show the transformation modal
Edit - Open the bulk edit modal
Actions - show the list of the available actions to be performed on the product/s
Flags - show the list of the available flags which can be used for the product/s
Actions:
Update Quantity - If clicked it will set Update Quantity = Pending for selected listings
Update Price - If clicked it will set Update Price = Pending for selected listings
List Update The Whole Item - If clicked it will set List Update The Whole Item = Pending for selected listings
End Item - If clicked it will set End Item = Pending for selected listings
End Listing - If clicked it will set End Listing = Pending for selected listings
Please note any actions performed affect just the selected listings!
Flags:
Close - If clicked it will set Closed = Yes for selected listings
Protect Price - If clicked it will set Protect Price = Yes for selected listings
Protect Quantity - If clicked it will set Protect Quantity = Yes for selected listings
Protect The Whole Item - If clicked it will set Protect the Whole Item = Yes for selected listings
