Integer
View:
Input field type number. Display is standard text view. The input accepts only whole numbers
Form:
Input type
Default Validators:
Numeric Validator with whole number option
Options:
MinimumValue - The minimum value that can be set for this field
MinimumValueNotInclusive - The minimum value that can be set for this field, without including the value
MaximumValue - The maximum value that can be set for this field
MaximumValueNotInclusive - The maximum value that can be set for this field, without including the value
