Create New Product (1)
The purpose of this page is to describe in details how we will create products in Hemi 3.0
Requirements
All requirements can be found here:
User Journey
The journey can be found here: Create Product - User Journey
Create New Product
It will be separated into 3 main sections- “Main“, “Bundle“, “Listing“ and users would be able to create & list a product from one place ( we will have 1 flow for creating and listing product)
Note: Below picture is showing general flow of creating & listing product. Each separate WF and its fields and buttons will be described one by one.
Complete flow:
Product Create flow - official flow.pdf
“Main“ section
Into the “Main“ section we will have 3 subsections, which will include the general(main) information regarding the product and the subsections will be separated with horizontal separator - “General“ subsection, “Media“ subsection and “Dimensions“ subsection;
The reason of combining the subsection into one page is to achieve better visibility and to save white space.
As per wireframe below, when section “Main“ is clicked, the tab will be colored in purple. Note: colors are not agreed, once we have approved colors, scope & wireframes will be updated accordingly.
Into this subsection we will have the basic information for the product.
All fields into subsection “General“ are described into the below table.
| Name of the Field | Field Type | *Required (In terms of required to be filled by user)** | |
| 1 | Title | Text Field | No |
| 2 | SKU | Integer | No |
| 3 | Application Data | Disabled (Filled automatically? ) TBD | No |
| 4 | Condition ID | Dropdown button with following options: |
New (with tags); New other (see details, without tags/box); New with defects; Manufacturer refurbished; Seller refurbished (Re-manufactured); Used (Pre-owned, Like new); Very Good; Good; Acceptable; For parts or not working; Like New; | No | | 5 | Variation Group | Text Field | | | 6 | Brand | Text Field | | | 7 | Barcode | Text Field | | | 8 | EAN | Text Field | | | 9 | ISBN | Text Field | | | 10 | MPN | Text Field | | | 11 | VAT code | Dropdown button with following options: Empty Value; 0; 5; 15; 20; | | | 12 | UPC | Text Field | |
“Media“ subsection
Into this subsection, we will have option for uploading images and videos.
Images - users would be able to upload images via 2 ways - with drag and drop option or uploading a file from browser; The first uploaded image would be main image, and the others would be the listing images. The main image should be bigger than the others in order to achieve visual effect.
User would be able to change the main image with drag and drop option, i.e as per example below, if user would want to make the 2nd image main, he should simply go to the second image and “drag and drop“ indicator should appear on hoover.
Each image should have an option to be deleted (x- button, located at the top right corner on each image)
Once images have been uploaded, there should be an option for reviewing each image via clicking on image box;
“Add more“ button should be frozen, i.e. if user upload 20 images, those images to not hidden or replace the location of button (maybe we can have kind of scroll or dots icon for visualizing all uploaded images.
Videos - users would be able to upload a video via 2 ways - with drag and drop option or via clicking on “add more“, selecting the video file and the uploading.
“Dimension“ subsection
There are no changes into this subsection.
Fields are described below:
| 1 | Weight | Text Field | No |
| 2 | Height | Text Field | No |
| 3 | Width | Text Field | No |
| 4 | Lenght | Text Field | No |
With clicking on “Next“ button into Main section, “Bundle“ section will be opened;
“Bundle“ section
“Is Bundle“ check box button will have 2 possible values - Selected or Normal. If user clicked on “Is Bundle“ button, it should unlock all fields related to this section - into the “Bundle“ & “Components“ subsections. If user didn’t click on “Is Bundle“, all fields into subsections “Bundle“ & “Components“ should be not visualized;
Condition 1: Is bundle check box is checked:
Condition 2: Is bundle check box is not checked:
“Bundle“ subsection
It will contain following fields
| 1 | Is Bundle | check box | |
| 2 | Is Expanded | check box | |
| 3 | Calculate Price | check box | |
| 4 | Bundle Error | check box | |
| 5 | Error Text | Text Field | |
| 6 | Parent bundle | Text Field |
It will contain following fields:
| 1 | SKU | Integer | |
| 2 | Quantity | Integer | |
| 3 | Discount Price | Integer |
”Insert new component” button will insert a new fields;
Here we have “Next“ button and via clicking it “Listing“ section should be opened; Via clicking on “Back“ button, Main section should be opened;
“Listing“ section
Into this section, users would be able to add listing, via using “Add new listing“ button, or to add listing on later stage (users would be able to close the pop up using X button at the top right corner. The important is all completed information for the product should be saved via “Add product“ button;
If user clicked on “Add new listing“ button, Listing subsections will appear. We will have “Listing“ section as a main section, and will have 7 subsections - “General“, “Categories &Descriptions“, “Item & Variation Specifics“ , “Shipping & Payment“, “Account Specifics“ , “Exchange Rate Calculator“ , “Others“
Note: Please, see below the description of each Listing’s subsection
Before subcategories, we will have a field for choosing account. It will be a drop-down button with options.
Note: Options will be described into the table below
Note: Wireframe above is applicable to “General“ subsection
All fields are described into the table:
| 1 | Select Account | DropDown button; | |
| Values : All accounts | Yes | ||
| 2 | Title | Text Field |
(it should be generated automatically from ’Title“ in “Main“ section > “General“ subsection Max: Min: | | | 3 | Sub Title | Text Field | | | 4 | Channel Item ID | To be filled automatically when account is chosen? (tbd) | | | 5 | Account | This field should be automatically filled when user select account from dropdown button “Select Account“ (num 1) | | | 6 | Seller | Drop-Down button with options; TBD options | | | 7 | Quantity | Integer | | | 8 | Quantity available | Integer | | | 9 | Quantity Last Updated | Date ( there will be calendar and clear option) | | | 10 | Account Profile | Drop-Down button with options; TBD options | | | 11 | Original Price | Integer | | | 12 | Price | Integer | | | 13 | RRP | Integer | | | 14 | Currency | Drop-down button with following options: Empty value; USD dollars; British Pounds; Australian Dollar; Euro; Arab Emirates Dirham; | | | 15 | Update Qty | Radio buttons with following options: Not Needed; Pending; Sent; Completed; Error; | Maybe will be deprecated from this section 🙂 | | 16 | Update Price | Radio buttons with following options: Not Needed; Pending; Sent; Completed; Error; | Maybe will be deprecated from this section 🙂 | | 17 | List / Update the Whole Item | Radio buttons with following options: Not Needed; Pending; Relist; Sent; Completed; Error; | Maybe will be deprecated from this section 🙂 | | 18 | End Item | Check box | Maybe will be deprecated from this section 🙂 | | 19 | End Reason | Text Field | Maybe will be deprecated from this section 🙂 | | 20 | End Error | Text Field | Maybe will be deprecated from this section 🙂 | | 21 | End Listing | Radio buttons with following options: Not Needed; Pending; Sent; Completed; Error; | Maybe will be deprecated from this section 🙂 | | 22 | End Listing Error | Text Field | Maybe will be deprecated from this section 🙂 | | 23 | Protect Price | Check box | Maybe will be deprecated from this section 🙂 | | 24 | Protect Whole Item | Check box | Maybe will be deprecated from this section 🙂 | | 25 | Close | Check box | Maybe will be deprecated from this section 🙂 | | 26 | Listing Status | Radio buttons: Active; Inactive; | Maybe will be deprecated from this section 🙂 | | 27 | Product Status | Radio buttons with following values: Awaiting creation; Product not created; Product created; Images uploaded; Product published; Product removed | Maybe will be deprecated from this section 🙂 |
The “Next“ button should open subsection “Categories & Description“;
The “Back“ button should transfer us to Listing section (3);
“Categories & Description“ subsection
The main change into this subcategory is it combines both “Category“ & “Description“. Both are separated with horizontal separator.
Into “Categories“ we have following fields:
| 1 | Primary Category ID | Text Field | Yes |
| 2 | Secondary Category ID | Text Field | |
| 3 | Store Category ID | Text Field | |
| 4 | Store Category2ID | Text Field |
Into “Description“ we have following fields:
| 1 | Description: | Text Field | |
| 2 | Condition Description | Text Field |
“Item & Variation specifics“ subsection
Mainly design changes. IS & VS will be separated with horizontal line.
For Item specifics we will have “Add rows“ button & option for deleting rows ( the x-button on each row)
Variation Specifics Fields:
| 1 | Variation Group PA | Text Field | |
| 2 | Variation Specific Name | Text Field | |
| 3 | Variation Specific Value | Text Field |
Item Specifics Fields:
| 1 | Item Specific Name | Text Field | |
| 2 | Item Specific Value | Text Field |
“Shipping & Payment“ subsection
The main change, comparing with current Hemi version is both shipping & payments are combined into one subsection
Shipping fields:
| 1 | Shipping template | drop down button with following options: | |
| TBD | |||
| 2 | Dispatch time max | Integer | |
| 3 | Is flat shipping charge | check box ( as described, it is applicable only for TradeMe) |
Payment fields:
| 1 | Immediate Payment | check box | |
| 2 | Payment Method 1 | Radio buttons with options: |
PayPal; PayPAI; PayPal; ManagePayments; Amazon Payments; | | | 3 | Payment Method 2 | drop-down button with following options: Empty Value; PayPal; PayPAI; PayPal; ManagePayments; Amazon Payments; | |
“Account specifics“ subsection
The important is when user select account from the drop down menu, specific fields for chosen account to be visualized into this section;
TBAdded: Fileds for specific accounts Bogomil Pavlov Danail Deltchev (Unlicensed)
“Exchange rate Calculator“ subsection
Fields into this section:
| 1 | Home Country VAT rating | ||
| 2 | Target Country VAT rating | ||
| 3 | Shipping Amount | ||
| 4 | Duty | ||
| 5 | VAT | ||
| 6 | Price Include VAT | Radio buttons with following values: |
Yes; No; Not Set; | | | 7 | List Logic | Text Field | | | 8 | Revise Description | Check box | | | 9 | Revise Description Error | Text Field | | | 10 | Product Category ID | Drop-down button with following options: TBD | |
“Others“ subsection
This subcategory will consist following fields:
| 1 | Specific field for deleting item | Text field | |
| 2 | Delete variant | Check box | |
| 3 | Delete Variant Error | Text field | |
| 4 | Discount Price Info | Drop-down field with following options: | |
| TBD - for specific accounts only? | |||
| 5 | Country | Drop-down field with all countries | |
| 6 | Return Policy | Drop-down field with following options: |
Empty value; Money back; Money back; MoneyBackOrExchange; MoneyBackOrReplacement; | | | 7 | Location | Drop down field with options | | | 8 | Design Template | Drop-down field with options: Default; Default template; TBD | | | 9 | Result | Disabled? | | | 10 | Error Code | Disabled? | | | 11 | Short Error Message | Disabled? | | | 12 | Long Error Message | Disabled? | | | 13 | Is Clearance | Check box | | | 14 | Skip Low Price Protection | Check box | | | 15 | Has Gallery | Check box | | | 16 | View Count | Integer | | | 17 | Random | Integer | | | 18 | Tags | Text Field | | | 19 | TBD | | |
This section will be the final step of the wizard.
Here we have an option “Back“ which will save the changes, but will not send the listing to the marketplace. Once user click “back“ button, it should open the Listing section (wireframe 3)
If user click on the “Add Listing“ button, confirmation box with following text should appear “Do you want to send the product to [MP name]?“ If user click “yes“, the Listing section (wireframe 3) will be opened and will contain the record for the created listing. Also, we will have a “Summary“ section, where we could see details for product we have created. The summary section is detailed described in document for “View Product“
If user click “no“, the Listing section (wireframe 3) will be opened and will not contain any record (TBD)
Via clicking on this icon, listing information should be opened in view mode;
Via clicking on this icon, listing information should be opened in edit mode;
Via clicking on this icon, users would be able to perform actions like Update Price, Quantity,List/Update the whole item, Zero stock update, Delisting, Delete; (TBA: Others will be added soon)
