Utilize AJAX for topic submission
Archived Stas K. ● 14 years ago
When a user enters an idea/problem/question/thanks, the form should perform an ajax submission for search results and display them in the same div as the form with no page redirect. If no topic is found, the Description box should be shown so that the user can enter their idea right then and there.
In addition, if results are found, the user should still have an option to enter a new idea (as a much smaller call to action) if they don't see their idea listed.
I see that it will be very similar to GetSatisfaction, and I assume it's very user-friendly. But as of now we are preparing stable 1.0 release and consider that feature if we have enough time to incorporate it.
Update: Done in 1.0.1
Replies (6)
115
124
That feature is done in 1.0.1 release!
129
Hey Stas - is it possible for this feature to be made available in the feedback widget as well? currently I don't see it behaving in this way here on the userresponse.com homepage
Thanks!
Dan
134
Currently it's not available, but it will definitely be integrated as we plan to incorporate one more widget with adding response from widget. We'll work on improving widgets right after 1.1 release and when we have more time. Probably it will be incorporated in 1.2, but we better wait for Help Desk Module, as we have it also in plans.. close to summer :)
128
Sounds great, very much looking forward to that summer release! ;-)
We'll probably start using UR after the 1.1 release, and will try to keep customizations to an absolutely minimum until the summer release.
Have an awesome day!
Dan
137
Quick Search and Quick Add are available in widgets from 2.0 release
