problem with facebook & twitter login integration
Archived Juan C. ● 14 years ago
Hi,
when trying to log with facebook or twitter on our website, there is a popup window that appears with our main useresponse url instead of facebook or twitter login screen. We have added keys for facebook & twitter, and even with google auth that continues with default key it has the same behaviour.
Regards,
Juan, this problem was fixed some days ago and will be incorporated in the next release.
See the solution on another discussion.
Let me know if it helped
Replies (4)
139
I see in url's they appear with one part of it duplicated:
http://factoriadigital.com/comunidad/comunidad/login-oauth/facebook?redirect=reset
Where do i fix this? the duplication happens even with google auth, that we haven't configured at all.
Regards,
135
127
Hi, that solved the bug, thanks :-)
I've found another one tho, if you don't login at first try, close the login window, and try to login again using any of the methods, the login window won't appear and you get an "Authentication failed" message from useresponse app.
Teste in firefox on macosx.
Regards,
133
Juan,
We've tested on your community and didn't identify that problem in any browser or OS. Used the same FF on MacOS.
Could you please clean browser cache and try again, as everything should work perfectly with any of the log in method.
If the problem still exists, please provide more details of the exact steps so we could check it one more time.
