Limit Knowledge Base Posts
Archived Matt ● 10 years ago
Is there a way to set a limit on the number or posts for knowledge base categories in the widget instead of using "all" or "featured" only?
Ideally you could select a number to show from all and have a sort order such as number of views, or usefulness (most up votes) etc.
Replies (1)
133
Well consider adding this option in the next releases.
