LDAP and Mobile interface does not work.
Archived Thomas K. ● 13 years ago
Hi there,
When using the LDAP feature with the mobile interface using AD you're unable to log in. It's simple responds with "Email or password are incorrect! Please try again!". Additionally the option to register is visible which we've disabled in the admin settings (and it's not visible in the desktop version).
What code is required to get LDAP/AD working without needing to use a 3rd party identity management group?
Regards
Thomas
LDAP login form is now fully supported on Mobile UI starting from 3.1.3 release
Replies (10)
144
Thomas,
LDAP authorization currently is not supported in Mobile interface. When you try to login into system using LDAP It displays default login form instead.
This omission is already in our roadmap. We plan to implement it in one of our next releases.
149
Hi Paul,
Is there any way I can force ldap in the mean time?
145
Hi guys,
Any ability to do this in the code? It would be really helpful.
Regards
Thomas
159
Hi Thomas,
We'll need several days to integrate it or if it's complex, we'll include it in 3.0 release.
167
Hi Stas,
That would if we could get it to us in the next few days, our use is for internal use only and LDAP for mobiles is a mandatory requirement. To be honest I was completely surprise that the LDAP integration wasn't in the mobile interface.
Regards
Thomas K
152
Hi Thomas,
Mobile interface doesn't give all features that desktop version has, so we recommend using desktop version primarily, and mobile UI only when needed.
157
Understood, the mobile interface would be primarily used for voting and submitting short queries in our use case
146
Any progress on this guys?
Regards
Thomas K
147
Hello Thomas,
We've decided not to make any serious changes in 2.3.x branch and concentrate more on 3.0 branch, where this change will be integrated sooner or later. Please use native login form to authenticate in the system with remember me feature. It should work for you without problems.
LDAP login interface is available only in desktop version as of now, but will be considered to be included in 3.x release
140
