Is it possible to get an RSS feed for Latest Questions?
Archived Dan &. ● 14 years ago
Our goal is to set up auto posting of new questions for example to Twitter/Facebook wall using a tool like Sendible which can import any RSS feed and post according to a schedule.
this will get others from facebook and twitter engaged into the community, leading to more questions and comments, more activity, more engagement.
just to clarify, am not referring to a feed for comments on a specific question - but rather a feed of latest questions. like a standard blog RSS feed of latest posts. :-)
Thanks!
Dan
Replies (3)
143
just saw you guys are pulling some sort of feed of "latest activity" from the UseResponse system onto the homepage of http://www.useresponse.com/
so as a follow-up to this question above, how is that being done on the UR homepage? we'd likely want to do the same on our website once we install UR.
Thanks!
Dan
130
Dan,
As system goes with open code, you can take any responses with the help of RSS or custom modules.
As of now we are working on API to provide easy integration with any 3rd party system and that could be done easily.
132
We'll try to integrate that feature by 1.2, but also full API will be available for 3rd party integration.
Currently, user can see Activity Log if that permission is switched on Guest Role and that information could be retrieved easily, like we did on our website.
