How to allow guest to comment a feedback
Archived HERAUD ● 6 years ago
Hello,
I would like to allow guests commenting anonymously a feedback (with moderation if possible).
Where can I set this up in the admin panel ?
Regards.
Replies (2)
125
Hi Rodolphe,
We've added this setting to your agent interface manually. To enable/disable guests commenting, go to Administration » System » Feedback and find the Anonymous Comments option.
The same moderation settings are applied here as you set in the Pre-moderate Community option in Administration » Support Channels » Community Portal. You can also find information about moderation here.
Kind regards,
Maria.
125
Thanks a lot !
Regards,
Rodolphe.
