When using the mobile interface SSO is ignored
Archived Stebi ● 13 years ago
When I use the mobile interface and click to login I'm not redirected to my site for SSO. Only the normal login form is displayed.
Fixed in 2.3.5.
Thank you for reporting a bug
Replies (4)
123
Which SSO do you use? How do you login? Could you, please, provide an image of the link you use?
133
We use the OneLogin method for SSO.
I get the wrong login screen when I display a topic and want to add a comment. Below the topic there is a login link which directs at /login?redirect=...
When I use the login link at the top everything works fine.
127
We identified this bug. It will be fixed in minor release.
120
Fixed in 2.3.5.
