What are system requirements for UseResponse?
Archived Stas K. ● 14 years ago
Where can I check system requirements for UseResponse? Is there a file or link where are listed all the requirements?
There are two ways to check system requirements:
- System Requirements at Admin documentation;
- You can download test probe file from your account->License Manager tab and upload it to your server. It will show you what you are missing. Pay attention only to issues.
Replies (11)
91
96
What are the drawbacks of having a useresponse installation on a php 5.2.17 environment?
100
It's a strict requirement to have PHP 5.3 or PHP 5.4, as in comparison to 5.2 version it's quicker and uses latest technologies to organize huge community with great performance of the scripts.
System won't just be installed on PHP versions lower than 5.3
91
Ok. Perfectly clear. Thank you Stas.
95
Sadly UseResponse doesn't work Out-of-the-box with PHP 5.4.
As a customer, you need to manually request a version without ZendGuard, as a non-customer you aren't able to run the free version.
That's why our company has chosen to stick with Uservoice :(
105
Sorry to hear that, but there are no plans for the free version to work on PHP 5.4, though we are working on commercial packages next releases to work out of the box on PHP 5.4
101
Our Corporate package doesn't need Zend Guard Loader. So all code is opened and works fine on 5.3 and 5.4
97
Now Free package is also working on PHP 5.3, 5.4 starting with Free 2.3.6 package. Non need in Zend Guard Loader any more
99
Great. Thanks.
103
Does the test probe also works with php 5.4 ?
100
Yes, it should work without problems. Do you experience any issues?
