useresponse vs. Zend Guard Version Problem
Archived Airwin N. ● 13 years ago
hi there,
i wanted to install useresponse on my debian wheezy with apache2 and php-5.4.x. so far i installed the zend-guard php-module as required. unfortunately i get following error:
PHP Fatal error: Incompatible file format: The encoded file has format major ID 4, whereas the Loader expects 5 in /var/www/useresponse/library/Useresponse.php on line 0
can you provide useresponse in compatible with zend-guard format ID 5?
thanks!
Starting from Free 2.3.6 - no Zend Guard Loader is required!
Replies (1)
97
