SSO fields not saving
Archived Anirudh ● 12 years ago
Hi,
I am using the latest beta version of your product and having a hard time integrating SSO. In the admin interface when I disable the native auth, it doesn't save into the database. I am manually entering into the database and tweaking the specific field. Could you please look into this?
Thank You
Replies (4)
118
Hello Anirudh,
Could you please tell me install UseResponse version?
112
Latest beta 3.0.2
117
Could you please clarify in more details if you click "Submit" button at the bottom of form? Maybe this is the problem? Because you need to click on Submit after selecting OneLogin method
119
Hi Stas,
Here are the Steps to reproduce:
1. Open the "Login Plus" SSO Tab
2. Select "OneLogin" in drop down
3. Set "Only use sso login" checkbox to "TRUE"
4. (This displays a new checkbox) Set "Don't send new account email" to "TRUE"
5. Press "Submit" Button.
Expected result:
The same settings are stored.
Seen result:
The "Only use sso login" checkbox is always set to "FALSE".
The other checkbox isn't even visible.
124
Hi Anirudh,
We still can't reproduce the error. Could you please send us FTP details or organize screen sharing? Send it to support(at)useresponse.com
