SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column 'value' at row 1
Archived Paul E. ● 12 years ago
We are getting this error by changing notifications for categories in the profilesettings after adding a new category.
Hello, Paul.
We have identified the issue. Table row ur_user_configs.value lenght is too short for serialized data, therefore data type should be changed to text instead of varchar(255).
Please execute the following SQL:
  1. ALTER TABLE `ur_user_configs` CHANGE `value` `value` TEXT CHARSET utf8 COLLATE utf8_general_ci NOT NULL;
Note: change the table prefix ur_ to proper if it differs from the default.
This fix will be also available in 2.3.11 within two hours.
Replies (1)
115
Hello, Paul.
