Sitemap Module daily task breaks
Archived Alexander K. ● 14 years ago
Just tried to get the sitemap to work, the cron job fails - because of the following message:
Parse error: syntax error, unexpected T_START_HEREDOC in ****/application/modules/sitemap/models/Sitemap.php on line 35
Tried to fix that somehow, but then getting:
Fatal error: Uncaught exception 'Zend_Http_Exception' with message 'Cookies must have a domain' in ****/library/Zend/Http/Cookie.php:124 Stack trace: #0 ****/library/Zend/Http/Cookie.php(359): Zend_Http_Cookie->__construct('PHPSESSID', 'b088c1f05a6dc75...', '', NULL, '/', false) #1 ****/application/modules/sitemap/models/Sitemap.php(190): Zend_Http_Cookie::fromString('PHPSESSID=b088c...') #2 ****/application/modules/sitemap/models/Sitemap.php(75): Sitemap_Model_Sitemap->_extractLinksFromUrl('http://www.shir...') #3 ****/application/modules/sitemap/handlers/Events.php(45): Sitemap_Model_Sitemap->generate('http://www.shir...') #4 ****/library/Singular/Event/Dispatcher.php(48): Sitemap_Handler_Events->onCronDaily(NULL) #5 ****/library/Singular/Event.php(89): Singular_Event_Dispatcher->dispatchEvent(Array, Array) #6 /us in ****/library/Zend/Http/Cookie.php on line 124
Because the Zend_Http_Cookie::fromString fails because of missing domain name for the cookie (maybe an error resulting of my "patch").
Problem fixed, Sitemap module archive updated.
Replies (6)
131
Thank you for problem report. Development team is working on fix for this issue.
130
Please unpack Sitemap.php from archive attached to /application/modules/sitemap/models/ and let me know if it helped.
115
123
Generation works now, thanks. I'm just wondering about this link in the sitemap.xml (it's the third one being generated)
<url>
<loc>http://www.shirtnetwork.de/suppor</loc>;
<changefreq>daily</changefreq>
<priority>0.80</priority>
</url>
This link does not exist, it could only point to http://www.shirtnetwork.de/support/
117
Please unpack Sitemap.php from archive attached to /application/modules/sitemap/models/ and let me know if it solved problem with invalid URL inserted into sitemap.xml
117
yes, much better - this is how i thought it to be. Thanks!
