Shall I do multiple installation in same domain
Archived Mohamed M. ● 14 years ago
Hello Support,
Shall I create a multiple instance with single license in a domain.
Thanks & Regards
Mohamed
Definitely no. UseResponse licenses are issued on per-URL basis. Multiple installations are not permitted and will result in your license termination, without refund.
Replies (14)
110
100
According to License Agreement - you can install system on single URL with one license, though it can be any domain, sub-domain or folder of the domain license is assigned to.
100
Can we then have one installation and multiple communities under separate categories?
123
Sorry, current functionality doesn't have this option either
93
But multiple communities under one installation is what is allowed as per this url:
https://help.useresponse.com/responses/how-to-support-seperate-communities-one-domain
103
you can break responses into categories, but this will be one community with responses visible to all members (if only you don't use Private Objects module)
101
Sorry, but what's Private Objects module and how does it change interaction/visibility/behavior?
95
Please check this response, it should give you an explanation of Private Objects module in relation to categories
https://help.useresponse.com/responses/how-to-implement-more-complex-category-structure
104
Private objects help you organize help desk within community, so that only authors can and official representatives see topics and comments within topics so they are no in public to provide support
111
Can we install on multiple sub-domains or directories for a single license as shown below.
http://www.domain.com
http://www.test.domain.com
http://www.test2.domain.com
http://www.domain.com / test
http://www.domain.com / test 2
Please let me know.
110
No, you can't. 1 url = 1 license
There are developer licenses for testing purposes
123
So you mean, we need to renew the licence every year for single site. If not this product gets locked by some means ?
113
You don't need to renew licenses as it's lifetime license and it won't be locked. It's optional. But if you want to get updates after 1st yeah, you'll need to renew.
120
Oh great! Thanks for clearing my doubts...just a pre-sale questions :-)
