Search engine friendly urls
Archived Amalgam V. ● 12 years ago
I see that my response is indexed in google without any keywords in the url.... however when I click on the url it brings me to a url that is does have the keywords. I'm wondering why the response isn't indexed to the url containing the keywords?
Example:
Actual url of response: http://www.northwestanswers.com/responses/dog-day-care-on-lopez
Url in google results: http://www.northwestanswers.com/response/63/vote/add/1‎
Thanks very much!
There is already fixed version started from 3.0.2 release
Replies (3)
131
Amalgam,
We'll take a look at the problem and get back to you during the day.
172
Amalgam,
Please find attached fix. Just reupload files to your server and it should work in several days when google reindex it.
Also, you better use Sitemap module in Extras to show correct links to the google and set up Daily Cron for it to generate and submit that Sitemap.
154
