Restoring UR on a recently wiped system
Archived Mathew S. ● 12 years ago
I have recently wiped my VPS and am currently doing a clean install of UR. I made a backup of UR before I wiped my VPS and I downloaded the zip file of the backup on my local machine. After I make a clean install of UR on my VPS can I restore UR from the backup zip file I have? If so could you tell me how or lead me to the proper documentation. Thanks!
Replies (1)
102
Hello Mathew,
The process of restore if the system is wiped is pretty simple. You need to make fresh installation, and restore from your copy of backup that was made before.
You can refer to this answer where you'll find all references.
