Problems setting up on Heroku
Archived Greg G. ● 12 years ago
I am trying to get the free version of UseResponse working on Heroku. I was able to get every installation check to pass except for a writable cache directory. I removed the "/cache" directory from the installation check script, which enabled me to complete installation, but now I get errors when I try to load the home page. The errors seem to point to the cache directory not existing or there being something wrong with it:
Got error 'PHP message: PHP Fatal error: Uncaught exception 'Zend_Cache_Exception' with message 'cache_dir must be a directory' in /app/library/Zend/Cache.php:209
Stack trace:
#0 /app/library/Zend/Cache/Backend/File.php(154): Zend_Cache::throwException('cache_dir must ...')
#1 /app/library/Zend/Cache/Backend/File.php(121): Zend_Cache_Backend_File->setCacheDir('/app/cache')
#2 /app/library/Zend/Cache.php(153): Zend_Cache_Backend_File->__construct(Array)
#3 /app/library/Zend/Cache.php(94): Zend_Cache::_makeBackend('File', Array, false, false)
#4 /app/library/Singular/Bootstrap.php(528): Zend_Cache::factory('Core', 'File', Array, Array, false, false, false)
#5 /app/library/Singular/Bootstrap.php(341): Singular_Bootstrap->initAutoloader(Object(Zend_Config))
#6 /app/library/Singular/Bootstrap.php(129): Singular_Bootstrap->executeResource('autoloader', Object(Zend_Config))
#7 /app/index.php(85): Singular_Bootstrap->__construct('development', Object(Zend_Config))
#8 {main}
thrown in /app
/library/Zend/Cache.php on line 209
Any ideas? Is there a quick way to just disable the caching? Heroku does not allow setting of permissions on directories in an application.
Appreciate the help, thanks for the great product.
Replies (2)
143
Update, it looks like when I pushed up my initial version of the application, the /cache directory was not included. I've added it and now I can progress to the next step of the installation. Will report back with any further issues.
143
Greg,
Glad that you've found the issue and resolved it. To get all experience of using our software, please create demo or use Corporate package, where support is included.
