Problem with Upgrade to 2.0
Archived Synergis A. ● 14 years ago
I just did an upgrade to my site and now when I go to Administration -> Settings or Administration -> Interface -> Widgets. I get the following error along with a crash report. How can I correct this?
Call to a member function renderViewScript() on a non-object
Please do the following steps:
  • Change the value of the field system_version field in settings table of database to 1.1;
  • Go to application/modules/system/Module.php and change to 1.1 in the following line:
  1. ->setVersion('2.0')
It should work for you.. Sorry for inconvenience!
Replies (22)
108
Could you please attach crash report to your problem? You may also send it to paul@uswebstyle.com. We need to determine this error using stack trace. Thanks.
107
Here are the crash reports.
127
Please try to clean cache. Click administration -> Clean Cache button.
This trick can help you, if not please notify me.
110
Paul Yakubets wrote:
Firstly try to clean cache. Click administration -> Clean Cache button.
Tried this. Still get the crash.
126
Did upgrade process finish correctly?
113
If you still have a problem please provide an FTP access as hidden text in comment or mail to support@useresponse.com. We need to see your remote scripts.
112
Does upgrade process finished correctly?
Yes
109
I need to do this tomorrow. It is on an internal server. I will need to make changes to provide access for you.
104
Did you change the code maybe by implementing some customization? Errors may occured after code changing.
100
The only customization I made was to the global.js. I have however since deleted eveything off the site and then upload the 2.0 files fresh from the zip file. I still get the error. Could it be an error with the data?
107
I having some problems providing you with access. Could be do a GoToMeeting so that you could look at things? Or I could send you a backup.
113
Synergis Administrator,
Please email backup of your files to support@useresponse.com and we'll take a look really quickly about your problem.
121
110
That did it. Thank you for your quick response and resolution to this problem.
103
You are welcome! Hope others won't have that problem, as newsletter with announcement will go out only next week
108
I can't see my UseResponse application after upgrade, I just see a blank page, Can anybody help me?
Thanks
112
Thanks
Cesar, I think you have UR installed in folder but not domain. Please open .htaccess file where UR is installed and remove line:
  1. RewriteBase /
We'll try to resolve such issues in future releases when customers have it installed in folder and upgrade it.
104
Cesar,
Also, if you don't have it installed in folder, please clean /cache folder
117
Hi Stas,
Sorry, I'm still with the same problem
112
Hi Stas,
Could you please provide access to ftp in spoiler here or in License Manager please for us to take a look?
112
Ready
100
Cesar, you already had that problem when you installed UR. Please refer to the following solution when next time you upgrade.
