Problem with top bar in mobile browsers
Archived Jirka M. ● 12 years ago
Hello,
after some problems already solved by your perfect support, I have one small issue
on mobile browser (Android chrome, Dolphin, ..), top menu that appear after scroll is only partially usable. Tap on "Responses" button immediately perform action and do not allows to select item from submenu. Because on mobile, you do not have any "onHover" action, there should be disabled action directly on "Responses" button
DPM5AfASXf5Jgo1Zc9GN
Replies (2)
111
Hello Jirka,
This is normal behavior of browser in non-mobile UI, as Responses is the link and can't have only onhover effect. For mobile devices, use mobile interface that is built-in. Of course, it's not the best option for tablets, but we'll definitely improve it in UseResponse 3.0
109
Ah good suggestion. Thank you, I'll enable it in settings
