"Polls" not work in latest 3.1.1
Archived Jirka M. ● 11 years ago
1. I've tried to add a new poll to help desk, but seems that selecting choice and pressing OK, just display small loading and nothing happen.
Please check it on our help desk site. Poll is added to main screen or is visible directly in topic. No change.
http://help.locusmap.eu/
http://help.locusmap.eu/topic/add-option-to-disable-load-map-tiles-animation-small-loading-effect-sux
2. I've then added second poll for testing. Both new polls are set as "featured" and by definition of widget, they should appear on home screen. Anyway "next" button that I expect should switch between polls, not work - never-ending loading effect.
The issue is fixed in 3.1.2 release.
Replies (3)
132
Hello Jirka,
The issues are identified and fix will be in the next release.
131
Thank you!
130
