PDO_mysql is required and not supported by my server. Is it really required for UR?
Archived Xenek S. ● 13 years ago
Hello,
I have a wave of green and one red. PDO_mysql. Is it really required? Can I install and use the free version without it? Could it be only required for the commercial version?
Thanks for making a free version of what looks like good software. Cheers
It's required but can be replaced with mysqli in config of ibstallation and system.
In /installation folder find application.inc and .default.inc and replace pdo_mysql with mysqli.
Also you need to remove check in code in installation script that checks for that extention and it should work
Replies (1)
93
