NOTICE (8) Uninitialized string offset: 0
Archived Макс Ш. ● 13 years ago
Hi,
Install 2.3.7 version, go to Analytics state and appears this error:
  1. Notice on line 624 in file mysite.ru/support/application/modules/system/library/Controller/Plugin/CrashReport.php, PHP 5.3.3 (Linux)
What happened and how to fix that?
Replies (5)
109
Макс,
We can't identify this issue.
Please, attach the screenshot where the error appears.
169
yMOszH81H7sgLsiRnsSV
98
Макс,
Please, replace /application/modules/system/library/Pchart/Data.php file with one from attached archive.
This should fix the error.
Let me know if it works for you.
101
Thanks a lot, that works!
100
administration
Fatal error: Uncaught exception 'Exception' with message 'iconv_strpos(): Detected an illegal character in input string' in /opt/web/oshelp/application/modules/system/library/Controller/Plugin/CrashReport.php:624 Stack trace: #0 [internal function]: System_Lib_Controller_Plugin_CrashReport->errorHandler(8, 'iconv_strpos():...', '/opt/web/oshelp...', 51854, Array) #1 /opt/web/oshelp/library/hotFiles.php(51854): iconv_strpos('2013-08-27', '??????') #2 /opt/web/oshelp/library/hotFiles.php(52117): Zend_Locale_Format::_parseDate('2013-08-27', Array) #3 /opt/web/oshelp/library/hotFiles.php(12116): Zend_Locale_Format::getDate('2013-08-27', Array) #4 /opt/web/oshelp/library/hotFiles.php(10565): Zend_Date->_calculate('set', '2013-08-27', NULL, 'zh_CN') #5 /opt/web/oshelp/library/hotFiles.php(9684): Zend_Date->set('2013-08-27', NULL, 'zh_CN') #6 /opt/web/oshelp/library/Singular/Module/Container.php(165): Zend_Date->__construct('2013-08-27') #7 /opt/web/oshelp/application/modules/system/Module.php(315): Singular_Module_Container->se in /opt/web/oshelp/application/modules/system/library/Controller/Plugin/CrashReport.php on line 624 Fatal error: Uncaught exception 'Exception' with message 'iconv_strpos(): Detected an illegal character in input string' in /opt/web/oshelp/application/modules/system/library/Controller/Plugin/CrashReport.php:624 Stack trace: #0 [internal function]: System_Lib_Controller_Plugin_CrashReport->errorHandler(8, 'iconv_strpos():...', '/opt/web/oshelp...', 51854, Array) #1 /opt/web/oshelp/library/hotFiles.php(51854): iconv_strpos('2013-08-27', '??????') #2 /opt/web/oshelp/library/hotFiles.php(52117): Zend_Locale_Format::_parseDate('2013-08-27', Array) #3 /opt/web/oshelp/library/hotFiles.php(12116): Zend_Locale_Format::getDate('2013-08-27', Array) #4 /opt/web/oshelp/library/hotFiles.php(10565): Zend_Date->_calculate('set', '2013-08-27', NULL, 'zh_CN') #5 /opt/web/oshelp/library/hotFiles.php(9684): Zend_Date->set('2013-08-27', NULL, 'zh_CN') #6 /opt/web/oshelp/library/Singular/Module/Container.php(165): Zend_Date->__construct('2013-08-27') #7 /opt/web/oshelp/application/modules/system/Module.php(315): Singular_Module_Container->se in /opt/web/oshelp/application/modules/system/library/Controller/Plugin/CrashReport.php on line 624
