Move posts between categories ?
Archived Robert B. ● 13 years ago
I look for a way and possibilities to move question, Posts,ideas and related answers from 1 topic/category to another ?
Is this possible and how is it possible ? If possible can it be done for multiple questions at the same time or just per question which would be a huge work after a while. This can happen as you find out that certain cetegories you defined are not good enough and you want to re-categorize. If you do so you want to move existing Posts to the new categories.
At the moment you have to edit each response to change its category. Go to edit respose by clicking "Edit" link
aLV7U7Ykbhx3y1AFJuzZ
and then select the necessary category:
YUO06CB4VBG7pBM6ct9J
Replies (2)
129
121
Update: now you can move topic between categories with Quick Edit feature.
