Migration from UserVoice problem
Migration Query is not working, as slug should be a unique value and all responses slugs comes asl null from the query.
Replies (6)
128
Fixed.
Slugs are now properly generated from imported topics' titles
135
Eduardo,
The problem was fixed with migration module, so you can try using it one more time to migrate from UserVoice
127
I've reset status for your migration, you should have it completed and with migration archive ready for download (with proper dump, since problems you've reported - are fixed).
128
Paul Yakubets wrote:
[p]I've reset status for your migration, you should have it completed and with migration archive ready for download (with proper dump, since problems you've reported - are fixed).[/p]
Thanks, it worked.
120
Ok, nice solution!
125
Thank you for report, problem is scheduled for fixing.
Update: Fixed
