LoginPlus: First login/post with LDAP Credentials
Archived Smarthouse ● 13 years ago
If an unregistered User tries to post an idea with his LDAP Credentials and the user is not already available in the Use Response "People" site, the idea/text gets "lost" and only the user is created.
From 2.3 release -user will be prompt to save data if he leaves the page and something is written in description field
Replies (3)
132
Thanks for sharing the problem. We'll check it and will try to provide you with solution or integrate fix in 2.2 or earlier release.
139
We'll integrate the feature to ask if user wants to leave the page with alert that all information will be lost. This is the only quick way to fix the problem and will be incorporated in 2.3 release
131
