Login Dialog does not display correctly on iOS
Archived Annevar M. ● 12 years ago
The modal dialog box that displays for the login, and register (even from /login) does not display properly on iPhone, iPad or iPod Touch. And I can replicate this problem on your 3.1 install, too.
68ce5934a8cc2ec0ab43247ad35e600e
This problem is already fixed. In 3.1 you can't check it as the latest version is located in our local git where only our company has access to. Though we are fighting with facebook login to correctly work smooth and on all devices
Replies (2)
128
121
Okay, that is great to hear. Well the login dialog not the Facebook stuff :P
Good luck with that!
