Knowledge base not compatible with mobile interface
Archived Kasper W. ● 13 years ago
When I search via the mobile UI, the knowledge base responses are not included.
Furthermore when I navigate to the knowledge base through the top bar at the mobile UI it is only the top bar that displays the mobile UI, while the rest of the page is the dekstop version. See attached screenshot.
Thank you for reporting a bug. Tweaked mobile UI to support Knowledge Base in 2.3.2 release
Replies (3)
103
Helli Kasper,
Thanks for reporting a bug. We are aware of it and fix in the next release
105
111
Done!
