Is it possible to hide the users top navbar?
Archived Mathew S. ● 12 years ago
I'm trying to integrate UR to look like our original sites theme and I was wondering if it is possible to hide the navbar that the user sees when the login? and is it possible to create and add my own custom navbar?
Yes, it's possible to customize or hide top bar for users. In order to do customization,
you need to create your own theme. Instructions could be found in Developer Manual
Then, you'll need to override in theme the following template, that is originally located in
  1. application/templates/layout/top-bar.phtml
Hope it will work for you
Replies (1)
98
