Installation Issues on Xampp
Archived AJ L. ● 14 years ago
I am attempting to install UR on localhost using Xampp (for testing). I cannot figure out how to get it to work as everytime I go to the install directory it simply shows me "Bad Request". I have installed ZendGuard also, is there any way to have some sort of walkthrough for installing it locally for testing? Has anyone succesfully done this using Xampp?Thanks.
Zend Guard Loader won't work on XAMP or WAMP required only for Free package. We tried to make it work, but the problem is in Zend, so you need to install PHP, MYSQL and apache as different instances for it to make work.
If you find any solution how to install Zend Guard Loader extention on XAMP, please let us know, as some of the users already reported that they can't do it.
Commercial packages can be installed without Zend Guard Loader
Replies (2)
130
115
Zend Guard Loader extension for windows does require PHP5 nts (non-thread-safe), most of WAMP bundles are using ts (thread-safe) PHP5 thereby it's impossible to have Zend Guard Loader extension working with these bundles.
