Install Problem
Archived Keith C. ● 13 years ago
I've installed Use Response locally and think it's a great system. When I tried to install it on a hosting provider - HostMonster specifically - it failed. First it wouldn't create anything past the first three tables.. then when I wiped the database clean and copied my local database up, I got the error below:
Parse error: syntax error, unexpected T_CLASS in /[web directory]/application/modules/system/models/DbTable/ResponsesTypes.php on line 1
Any suggestions?
Replies (2)
121
Hi Keith,
What PHP version do you have On HostMonster?
Also, make sure you reupload files using binary mode and do clean install.
Let us know if it helped you
135
Sorry for the delay in getting back to you.
It ended up being an issue with not using binary mode to do the upload. It was breaking the install process after the first three tables.
Thanks for the suggestion. :)
