How to bypass single sign on for admins
Archived James G. ● 12 years ago
Have uploaded and setup live version, but the SSO settings are incorrect. I'm pretty sure I remember reading somewhere that sso could be bypassed, but I can't seem to find it.
Replies (4)
119
If you set only SSO method in module settings, you'll have only link at the header or redirect to SSO login page on any action. You can change that setting to have standard registration/login and also SSO in Administration-Single Sign-On:
xc5v6MHg29fKfoPRlRp4
Let us know if it answers your question.
109
If you want to login to Administration area and you have only SSO to be used, please use following link:
http://www.domain.com/login
103
I did try /login, but my mod re-write rules we're slightly off so I was getting a 404.
Sorted now,
Thanks.
104
You are welcome... Glad that it worked for you
