embedding Knowledge Base on external websites?
Archived jasperisu ● 13 years ago
Hi there
you wrote about the KB : "insert on any website with the help of widget".
does that mean external websites (non-UR)?
and how does this work? Is there a widget that generates HTML to embed?
thanx!
Yes, you can embed widget form inside any page of any website outside UR. Just go to Administration->Widgets->Knowledge Base and specify parameters. Then click on submit, and get code to insert into any page.
Replies (2)
127
125
fantastic! :)
