Cron is not running
Archived Mohamed M. ● 14 years ago
Hello Support,
we are using useresponse1.0. We have given the cron entries in our server also assigned for frequently,hourly and daily with respective timings.
While I am getting the cron output as a text file, it is showing a error.In Admin cron executed timing also not updated.
Please let me know, from license key which value I have to mention in the cron entries.
Regards
Mohamed
Hello Mohamed,
The problem was solved in 1.0.2 release. So you better update to the latest 1.1 release if possible to have it resolved on your side.
Replies (2)
107
Hello Mohamed,
120
If you are not able to update due to some reasons, please use alternative option to execute Schedule Jobs with the help of Curl
More about this could be found in Scheduled Jobs Manual
