MultichannelPro v 1.0.0 Released
Release notes - Hemi Connect - MultiChannel Pro Version 1.0.0
Story
HEMISPHERE-17561 [Amazon SP API] Taxonomy
HEMISPHERE-17563 [Amazon SP API] Listing Create
HEMISPHERE-17564 [Amazon SP API] Listing Update
HEMISPHERE-17565 [Amazon SP API] Listing Delete
HEMISPHERE-17620 [Amazon Smart Connect] Get Returns Amendments
HEMISPHERE-17621 [Amazon Smart Connect] Get Shipments amendments
HEMISPHERE-17628 [Amazon SP API] Notifications
HEMISPHERE-17640 [Amazon Smart Connect] Include overlap when getting returns
HEMISPHERE-17647 [Custom] Orders Export for LSH
HEMISPHERE-17721 [HemiOS Redesign] Additional style amendments
HEMISPHERE-17727 [eBay] Product GPSR Incorporation
HEMISPHERE-17730 [Arett EDI] Stock intake
HEMISPHERE-17731 [Arett EDI] Order Export
HEMISPHERE-17732 [Arett EDI] Order Acknowledgment intake
HEMISPHERE-17733 [Arett EDI] Order Shipment intake
HEMISPHERE-17737 [Amazon Smart Connect] Trimm 'minus' sign when saving discounts and sum product discounts as total order discount (Puma-UAE)
HEMISPHERE-17741 [HemiUI] MC Pro redesign - things to add and change if possible
HEMISPHERE-17767 [Core] New fields for the invoice functionality
HEMISPHERE-17780 [Core]Update UI Forms
HEMISPHERE-17781 [Core]Update UI Form Fields
HEMISPHERE-17784 [Core] End Item Error Field Update
HEMISPHERE-17798 [Core] Amazon Prime and Premium Shipping Service Mappings (Puma)
HEMISPHERE-17816 [UI Reskin] Bring in option in Hemi to switch between old UI and MC Pro version
HEMISPHERE-17828 [Core] Missing field in 'Account Arett' (arettsales)
HEMISPHERE-17849 [Core] Custom orders export (hpc)
Bug
HEMISPHERE-17637 [Amazon Smart Connect] Get returns not working as expected (Puma-UAE)
HEMISPHERE-17639 [Amazon Smart Connect] Get orders filtering 15 months in the past (Puma-UAE)
HEMISPHERE-17760 [Amazon_v2] Quantity updates do not change 'Last Quantity Value Sent' and 'Last Quantity Sent Time' fields
HEMISPHERE-17801 [Analytics Feeds] Problem with sending request
HEMISPHERE-17818 [eBay] Products stuck on sent status (jlr)
HEMISPHERE-17830 [LaRedoute Mirakl] Get orders getting stuck (Next)
HEMISPHERE-17833 [Shopify] Missing cancelation status in Hemi (hoover-candy)
HEMISPHERE-17835 [Core] Update PHP version for /var/www/alpha/Hub/cron/cron_sys_011_order_item_bundle_add.php
HEMISPHERE-17836 [eBay] [GPSR] /var/www/ebay/bin/image/cron_ebay_021_update_image.php doesn't have PHP version in cron tab group
HEMISPHERE-17868 [Amazon] Feeds stuck on 'Processing' (Puma)
