Allow enable/disable of topic types per forum
Archived Charles W. ● 8 years ago
On some of our forums, we want only ideas or only problems but we can't do this because topic types are enabled "universally". This makes it difficult to set up forums for different purposes. The option to enable or disable topic types per forum would make the platform a lot more flexible.
Replies (1)
130
This idea didn't find enough votes for the past 2 years and won't be done, as there are technical and logical limitations in automation processes that will make management less user friendly.
