Add ability to sort by view column for KB articles
Lee Roquet shared this idea 14 months ago
Completed
It would be great to add the ability to sort KB articles by views so it makes it easier to select which article should be featured each month. We rotate the top articles so users see the top hits. Now you have to scroll down to find what you want to mark as featured.
Comments (3)
Good
Hi,
the ability to sort articles by views is available for you.
We also fixed the issue with sorting that didn't work when one of grouping parameters was selected. The fix will be available in the next release.
Kind regards
Thanks Liza this is great
Lee Roquet / CCO
Yellowfin
