Arcade Customizations / Tracking Return ID Split
Tracking/Return ID Split
In Arcade2 instance (https://arcade2.wearepentagon.com/alpha/en/home) there is a custom Export → Import that splits the tracking number and return ID. The reason behind that is that both values come in the same field with the shipping imports from ProSKU. What happens is we read the first shipping import from ProSKU and do not raise the update shipping pending flag (at least for some marketplaces). After that an export (you can find the SQL querry below) splits the tracking number and return ID in different fields after which they get imported in Hemi that way.
Export Layout ID: 42 (Shipping Export (RetrunID split))
Export Feed ID: 37 (Shipping Export (RetrunID split))
Import ID: 388 (Combined Shipping Import)
Return ID split querry.txt
