Is your system scalable in UI, languages, modules?
You'll be surprised how flexible and scalable the system is with the following functionality:
  • Themes - allows you to create your own or change a default one to match your website UI;
  • Applications - as the system is modular, you can build any module on your own or customize existing ones to expand functionality and integrate any feature you are interested in;
  • Localization - you can add your own language and translate the interface with the built-in tool. A big advantage is that you can change the naming of any word or expression if you have specifics in your company or business.
