Hemi User Guide
Hemi technology
Contents Hemi technology 1. Introduction 2. Group rights 3. Products 3.1 Product Details: 3.2 Product Accounts: 3.3 Location Quantities: 3.4 Products: 4. Orders 4.1 All Orders 4.2 Detailed view of Orders 5. Search logic 5.1 Search for a specific value (exact match) 5.1 Search with a specified pattern 6. eBay messages 6.1 Navigation 6.2 Types of Threads 6.3 Types of Messages 6.4 Lifecycle of the message/thread 6.5 How to answer a buyer's request/message 6.6 Errors 7. Message Tempaltes 7.1 Create a new Template 7.2 Edit already created Template 7.3 Delete/Hide a Template 8. Custom Views 8.1 Working with custom views 8.2 Bulk view of custom views:
1. Introduction
The purpose of this document is to give you a good understanding of Hemi Technology features, structure and more specifically the following developed functionalities:
- Group Rights
- Products
- Orders
- eBay Messages
- Custom Views
Please note the layouts attached below are only for example purposes. Each section layout can be amended in terms of what information to be displayed in order to meet the user requirements and up to the specific group right assigned. On all screens you will find several main icons and buttons for navigation and commands:
-"View" Used for entering a detailed page of the selected records row. Available in all screens, always at the right end of a row under the Actions column.
- "Edit" navigates directly to an Editable page of the selected record. Available in all screens but only for specific users with the relevant levels of access. Always at the right end of a row under the Actions column.
- Sowing the number of records to be shown in one page. Customisable for each screen/View and user. Always available in the top right section on the screen.
- Triggering a search action of the selected criteria. Search fields are always located under the header row followed and the Search button always at the right end of the row, under the Actions column. Find more details in the Search Logic section in this document.
- Used to clear the already selected search criteria. Always located at the top right corner of the view page.
- Available in some sections. At the top right corner next to the Clear Sort button. Used for Bulk updating information based on the selected criteria in the View page.
2. Group rights
Hemi Technology supports different groups of users to be set up, restricting or allowing access to specific features in the Instance, based on each individual operational needs and position. For the purposes of the daily management and monitoring, several groups were created delivering the user needs of particular team member. For example, only specific users can action refunds and custom views or edit product content. If a new user should be created or a level of access should be changed, please log a ticket* to the Hemi Technology Support team and it would be actioned.
3. Products
A section, visible to all users. The Products tab in Hemi Technology has 4 different sections. Each one of them represents a different layer from the entire Products section. This is the place where all products are being monitored, listed, updated and managed. Depending on the user permissions, a user can either view, view and edit or cannot see this section at all.
This table contains the general information for each product (SKU) which can be listed on multiple accounts (marketplaces). Bulk view of product details:
On the Bulk Records View a user can find basic information on the main product level as: ID (Internal identifier in the system), SKU, Inventory Title (if provided), Condition, Variation group (if any). All of the field are searchable either via a conventional filter or via free text in line with the search terms in Hemi Technology (separate guide provided).
Detailed view of product details:
Information like SKU, Images, Barcodes, Condition is held in product details level and this information is shared across/unified for all accounts (marketplaces). The Bundle Tab, next to the Main Fields one, shows specific Bundle flags used for the product data management of the catalogue. The second part of the Product Detail section presents 3 different Tabs:
- Product Account - more details available in point 3.2
- Bundle (Records) – providing information for the components included in the bundled set (if any) and their quantity.
- History – showing logs from the history of the applied changes to the record.
The purpose of this View is to distinguish the information which we send to each account (marketplace). In Hemi Technology you can have a single product detail with many product accounts for different marketplaces e.g. SKU: 1234 to be listed on eBay UK, Amazon DE, eBay FR at the same time by only adding the desired product account.
Bulk view of product accounts:
This View has a similar layout to the Product Detail one but showing slightly different information. Ex: Quantity and Pricing, Listing Title, Category IDs etc. From here, you can easily navigate and go to the Detailed view using the "loop" icon or use the various search filters to extract specific information.
Detailed view of product accounts:
The information held in product account is specific for each marketplace. Ex: Title, Quantity, Price, Currency, Description, Item and Variation specifics, Shipping, Payment Methods etc. This information is separated in different Tabs grouped by meaning. Main Fields:
- Title – The marketplace listing title of the product
- Sub-title – A product's sub-title (if any)
- ChannelItemID – this is a unique identifier which the relevant Marketplace returns when the product has been listed successfully.
- Account – the marketplace where the product is listed.
- Seller – there is capability of storing different Sellers per marketplace account (ex: suppliers). Set with a default value of the used account.
- Account Profile – This field gives you the functionality to have a high-level control over the selling items. Maximum and minimum quantities could be set. For example, if we set max quantity = 10 this means if there are more than 10 units available we will always send 10 to the marketplace. If we set min quantity = 5 this means if the quantity available is less than 5 units or equal to 5, then 0 will be send to the marketplace showing the product as unavailable for sale (Out of Stock). The minimum level border is considered as a buffer level and used effectively when there is a shred stock between multiple marketplaces and/or between e-commerce platforms and local network of shops. This is lowering the chance of receiving back orders because the item was purchased at the same time from multiple sources.
- Quantity – the quantity send to the marketplace after buffer is applied.
- Quantity Available – the available stock levels before the buffer is applied (*it is being updated on different margins depending on the actual levels and changes to the free stock).
- Price – the product's selling price for the specific marketplace
Categories &Duration:
- Primary Category ID – The marketplace category ID where the product is listed
- Store Category ID – The shop category ID (if any design available)
- Listing Duration – "Good 'Till Cancelled" by default
- Listing Type – "Fixed price" hardcoded
Description:
- Description – stores the full product description. HTML supported and passed.
Items and Variation Specifics:
- Variation Group - Populated if any available. Used for products in series.
- Item specifics – Item specifications used for the product optimisation and meeting the requirements of the specific marketplace.
- Variation Specifics – Holds specification values for the products presented as variations.
Shipping:
- Shipping Template – different shipping templates could be used and mapped on an SKU account level. The field contains the selected shipping template of a pre-set list with options.
- Dispatch time Max: -1 value indicates a Same day shipping prior to the cut-off time.
- Is flat Shipping Charge – Set to NO, as there are various shipping options.
Payment Methods:
- Immediate Payment – Always set to Yes, uses the default payment method by the marketplace.
Other: Additional fields to the section, intended to be used by the management parties in Hemi K Codes:
- K Codes – stores specific fitment information (if any available in the product data files) and imported/managed by the Hemi Inventory team.
This section if the menu contains the actual stock in the warehouse/s which is imported in Hemi Technology by the provided stock update files.
View of Location Quantities:
There are 3 different types of quantities in Hemi Technology.
- Location Quantity (Location Quantities Table) – the total stock in the warehouse as per the latest stock updates.
- Quantity (Product Accounts Table) – the stock after buffer`s calculation which is sent to the marketplace.
- Quantity Available (Product Accounts Table) – the available stock before the buffer`s calculation. It is shown on a Product Account level and being updated based on the changes in the stock levels (i.e. higher quantities with small differences -> less updates; lower quantities ->more frequent updates).
3.4 Products:
Products table is a mixed view based on Product Details and Product Accounts tables.
4. Orders
The Orders section in Hemi Technology has different tabs for each different order status. It is used for orders management activities and tracking and gives a detailed information on the sales activities.
4.1 All Orders
A screen showing all placed orders, including additional information as: Status of the Order, Buyer details, External reference IDs (Marketplace) and other.
This is the main screen for navigation to all order details.
Use the "View" icon at the end of each row to access the Detailed Order screen. It is presenting the complete order information as details of the placed order time and channel, shipping and billing buyer details, products in order, payments and refunds if any.
All the rest Orders Sub-menus are identical to each other. They are similar to the All orders screen but yet divided and grouped by Order Status hence you can easily navigate and track them for reporting purposes.
5. Search logic
There was a new Search logic released into Hemi Technology which is more flexible and faster. It is applicable to all fields in all sections within the Instance allowing a free text input. The functionality is now aligned to look for the "exact match" results of the phrase/number filled into the search field. Below you will find all options that could be used for finding a specific record in the Instance.
This way the system will search for a specific SKU "123". It is the default search logic used by the tool and it will always look for exact match result when a text only is entered.
If you are unsure about the complete text, you can use only a part of it as a search term and use an asterisk sign ⭐ at:
- the beginning of the text
- at the end
- both.
Please note this works only at the beginning or the end of the string (123) cases like "1*23" will not work!
- text
This way we will search for anything that contains "123". The symbol * means anything before "123" and anything after.
- text
This way we will search for anything that ends with "123". The symbol * indicated we are looking for any value before "123".
- text*
This way we will search for anything that starts with "123". The symbol * indicated we are looking for any value after "123".
6. eBay messages
The daily account management of the Customer Service Team activities for eBay is actioned via Hemi Technology under the System tasks/ Message Threads section. There are specific steps performed on a daily basis from the team leaders, Cashier and CS officer to deliver a seamless and sustainable process.
The main difference that should be done here is between a thread and a message.
- Thread - a grouped conversation by an opened by a buyer topic. It contains both client messages (questions) and Team Replies. All threads are presented in the main Messages screen.
- Message - part of the conversation initiated by the end buyer and represents their query or the Reply actioned from the CS team.
6.1 Navigation
The navigation through this section is identical to all others. You can either use the drop-down menus to limit the results by the desired criteria or to use a specific text/ID for a more detailed SERP. The fields that could be filtered by a drop-down menu are:
- User
- Account
- Status (of the message)
- Type (of the message)
Flag 1/2 (if used for an indication)
Again, the View and Edit buttons are available to navigate you to details of the selected row of records.
All incoming threads are being distributed in 4 types of groups by HemiT automatically via specific and complex criteria:
- Order Related – Indicates that buyer has noted their query as related to a placed order
- SKU Related – Indicates that the buyer has notes their query as a product related
- General Questions – General questions placed by buyers using the Contact-us form in eBay. Could also be a pre-sale related query.
- System messages – Not all messages are intended to be answered. There are system messages send out automatically from eBay as a notification for expected action to be taken or as a confirmation of such.
- Client Message
- Reply
The type of the message indicates whether the buyer has placed it or it is a reply from the CS team. This allows monitoring and data that could be extracted for reporting purposes. All messages related to the same threaded are grouped together and shown under the Main Thread Details under the Message Records section:
There is a lifecycle of each message row that is being added and also to each conversation thread.
- Creation
The first and initial phase is started when there is a new buyer request on eBay. When the message is placed on the marketplace, it will be downloaded into the tool per the set schedule. At the moment of download, it will be automatically a new Thread to be created including all details from the request and the related and identification IDs. The status of this thread is "Waiting Response".
- Assignment
The next phase of the lifecycle is the assignment of the created Thread. This is being actioned only by the CS Team Leader who is distributing all incoming messaged between the CS Officers. There is no change to the status. It is still Waiting Response. Only an assignee is being added.
- Reply
The next step the already assigned CS Officer to reply the query (steps for How to answer a Message are added in point 6.5).
After a Reply was added, a new row will be automatically added to the Detailed page of the Thread:
The Status of the Reply Message will be shown as "Pending" until it is sent to eBay. Then it will be automatically changed to "Completed"
- Status Change
After a Reply message was placed, there are 2 options:
The message has been successfully sent to eBay and the Reply message Status has been automatically changed to Completed. This will trigger an automatic update to the thread status as well, changing it from "Waiting Response" to "Replied" in the main Messages screen.
The second option appears when there was an issue of the message processing and it didn't reach eBay. More details also included in point 6.6 The message hasn't been successfully sent to eBay and the Reply Message Status is automatically changed to "Error":
This is also reflecting to the main thread one which is also automatically updated to "Error.
<img src="/public/temp/3e7f3f26a546f8817a36fdb5baa8cb73.png" alt="">
<img src="data:image/png;base64,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" alt="">
- Completion
When the message has been successfully changed and the status was updated to "Replied", the message thread could be completed if considered by the CS Officer as resolved. This Status change is manual and is responsibility of the assigned user who should be actioning the thread. The thread that should be completed should be changed from the Edit button in the Main Messages View:
Or directly from the Thread detailed page once the status has been changed to Replied:
With this step completed, the buyer's request is considered as requested but please keep in mind that this only an internal status kept for reporting purposes. The buyers always have the opportunity to return a new message to the Conversation and this will trigger an automatic Status update again and will return the Thread status back to "Waiting Response":
In this case, all steps listed above should be repeated again except the assignment one, because the new message came in is part of already existing conversation/thread:
6.5 How to answer a buyer's request/message
- Go to the details section of the select the message using the View Icon at the right end of the record row.
- Using a right mouse click, open the Client message in a new Tab to read the request.
- You can either reply from the new window clicking on the Reply New Message button at the right bottom of the screen (this will hide the client message):
Or go back to the previous tab and click on the Reply Message icon:
Either way, a same Reply window will be show on the screen.
- Type your response as a free text or using one of the created Templates:
- Once ready, simply press the Reply button at the right bottom of the screen:
This will record your answer and a new row will be automatically added to the Detailed page screen with Type: Reply.
6.6 Errors
Some of the Thread statuses are directly linked to a Reply Message's ones. For example, if after a Reply Message has been added and for some reason it didn't go through or there is another issue in place:
this will result in automatic change of the main thread status to "Error" so this could be monitored and investigated.
In case of any Errors appear, please contact the Support team, so the issues could be investigated in details and sorted out.
7. Message Templates
A section in the tool, visible for a selected group of users, allowing creation and management of different Message Templates that could be used by the Customer Service officers when applicable and on a case by case basis.
7.1 Create a new Template
The creation of a new message Template is fast and easy.
- Go to the System Tasks Menu and select the "plus" button:
- Fill in the new template name, the text for the template and choose if it should be visible at the Reply section:
- When ready, save the details using the button at the right bottom.
The template you just created is ready for use and will be immediately visible in the Message Reply section.
7.2 Edit already created Template
If you want to apply any changes to already created Message Template, only 2 steps should be actioned:
- Go to the Message Templates Menu and click on the Edit Icon:
The editable box will be opened and you can apply the text changes.
- When ready, simply Click on the Save button and all changes will be saved:
7.3 Delete/Hide a Template
If there is no longer a need for a specific template to be in use:
- Go to the Message Templates section in the Main Menu:
Find the template you would like to deactivate using its ID or name and Click on the Edit button at the end of the Row.
- When the dialog window is open, simply untick the Active checkbox and then on "Save"
This will hide the template form the Message Reply section and it could not be used for a pre-set answer to a buyer query.
8. Custom Views
The purpose of the Custom Views sections is to give you customised view of different pieces of information. They keep the standard navigation as all other Views and you can also search, sort and bulk update them. Again, this is section is not visible to all users and it is subject of specific level of access.
Working with custom views
Bulk view of custom views:
In order to apply the custom view, you have to click on
and this will give you the results from the view.
Detailed view of custom views:
When all results from the auctioned View are presented, you can sort them by the most relevant for you way using the available drop-down menus or search by specific text in the other fields. You can view each record
, edit each record
or bulk update all the records
- View a record
If you click on view
you will be navigated to the detailed view of the record:
- Edit a Record
If you click on edit
you will be navigated to the edit view of the record:
- Bulk Update/Assign Records
If you would like to bulk update all the records in the custom view you click on
Please note if you filter your custom view with a specific criteria and Bulk Update any of the fields you will only update the result from that filter.
THANK YOU FOR YOUR TIME!
