Upvote 1
Using LDAP sing-on with combination of default login
Completed Mirjana Bota 5 years ago
Hello,
we have self-hosted application with FW version 4.8.1.
We would like to integrate 2 ways login using LDAP and native login.
Is it possible to combine this two login options so user login fails only if both failed?
I found the old link that has negative response.
https://help.useresponse.com/topic/are-you-able-to-use-ldap-and-onelogin-in-conjunction-with-each-other#comment-2675
Replies (1)
2
Yes, you can combine ldap and native login. Just use "Use Only Single Sign on" setting in Administration - Login Plus - Single Sign-On. Once you select LDAP method it would advise you the option
More details could be found here https://help.useresponse.com/knowledge-base/article/using-ldap-as-a-single-sign-on
